HElp
MArsel
I have 2015 rang rove rang rove Evoque 2.0 turbo for some reason the car will not start . live date it show me that is missing signal request . when i send starter request via BCM with my scanner the car start but by her on, it will not start .
so far i replace both battery's new starter new relays new brake pedal switch new stop/star switch , i check the BCM for water intrusion . i check voltagge on the relays o have voltage and ground . it show me p0512-12 code starter request
did some one run in this situation with rang rove . pls i need answer
FlindersLR
