2008 L319 Pulling C1131-92
ch1819
Florida
What I’ve done so far:
  • New OEM AMK compressor installed ~1 year ago (plus reservoir tank, center valve block, and front valve block replaced at the same time).
  • Replaced fuses FL10, F26, F3, F35
  • Replaced relay (R7)
  • Battery disconnect (15 min) – no change.
  • Cleared code multiple times with scan tool – code comes back instantly, compressor never even attempts to start.
  • Scan tool shows:
    • Compressor relay = OFF (never commanded ON).
    • Compressor voltage = 0 V.
    • Pressure sensor Vref = 4.9 V (so ECU is powering it).
    • Gallery pressure stuck at ~12.8 psi.
  • Rocker panel under passenger door had water intrusion (sunroof tubes duh); loom dried but still suspicious
  • Current suspicion:
  • ECU is not seeing a valid signal from the reservoir pressure sensor (inside reservoir valve block).
  • Either the sensor itself is bad OR the signal wire is open/corroded in the passenger rocker loom.
  • Next step I’m considering:
  • Running a continuity test from the pressure sensor signal wire at the reservoir valve block back to the suspension ECU behind the glove box (long jumper wire).
  • Question for the community:
    Does this sound like the right next diagnostic step? Has anyone else confirmed a rocker-loom wire failure (open or corroded) as the root cause of a C1131-92 with a non-running compressor?
