OBDII Scanner
D
discoV8nut
Hi everyone. I am thinking of buying a new OBDII scanner to read my codes, but will this clear my recurring triple light show (ABS-HDC-tc) brought about by squealing brakes?
Regards
Roger
Sorry, but no it will not clear the triple lights... you need testbook or similar dealer computer.
witecaphyr4u
does your triple lights stay on after turning off the vehicle?
When I get the lights, I just pull over and turn the car off and restart and its gone.
CSeel
Triple lights are just on the D2.
D
discoV8nut
Thanks joey, is testbook available easily? or should I just sort the squealing brakes and get the stealership to reset the lights.
Regards
Roger
http://www.rovacomlite.com/ = cheap version of testbook (not the $10k version)
Squealing brakes = could be anything from a stuck caliper to the type of brake pads you are using....
PE_in_UAE
