P0441 error code
DrkNite
P0441 error code (More Codes and Update 1/2/16)
Well with typical holiday luck something went wrong and my wife's 2005 LR3 V6 broke down yesterday.
When I got to it, it would start then stop again and was throwing a p0441 and p0069 codes.
I got hold of a replacement gas cap and cleared the codes, at this point it started and I was able to get get it home.
After getting it home I tried to start it again and it again threw a p0441 and this time a p0402 code. again with the start stop.
left it over night an tried it this morning and it started no code.
Didnt leave it running and i think it's only throwing the codes after it restarted when its warm.
anyway i've do some looking on here and other site on the net and it looks like i might have to replace the purge valve which i'm willing to do however I can t find the correct part number anywhere, can some one confirm my assumption that this is what i need to replace and tell me the part number of the purge valve for the 2005 LR3 V6 4.0l
thanks.
DrkNite
Update
OK so update.
Left the LR stood for a week and it started right up added some gas to it and it ran fine, even restarted no problems.
left it to sit 20 mins and tried again, wouldn't start again....
However this time it threw a completely different set of codes, got 2 P2100's.
Going to try cleaning the throttle body and see if it helps.
DrkNite
2nd update for today
Went to try and move the LR for i could get to the engine bay and no start, but just in case I thought i'd checked the Codes again.
this time no p2100 but I did get a P0069, starting to this the problem is more of a sensor issue that a real problem with operational parts? Suggestions?
DrkNite
Final Update on this
So bit the bullet and got the LR to the local indie.
Diagnosis pressure sensor in the EGR valve, $550 later (Diags, labor and part) we are back on the road again.
STQAddie91
