Really Need Your Help On This One
Cheech401
I currently own a 2007 RR Sport Super and I am getting all kinds of warnings going off at the same time. Some of these include Transmission Failure, Suspension Lowered, and Dynamic Response Unavailable to name a few. Please tell me that someone else has experienced this before and you were able to find a solution.
Cheech401
I've had the battery checked and the battery life is still at 98%. Alternator also diagnosed as being good. This happens when the vehicle is actually running and tends to happen when I slow down or come to a complete stop.
Brake Pedal switch; brake lamps in the back...check the bulbs and make sure that they are LR replacements.
socalrovershop
the brake pedal switch is a two stage switch the first signal is for the high speed can for the abs system second is for the lights only way to see if this is bad is going to a good known shop who has the right tools/computer to check out the signal coming out of the switch. that or take it to the dealer. orrrrr go to ford and get a brake switch witch will save you alot of money but its a 50 50 shot with out diagnosing it
PE_in_UAE
