Relay R1, 2011 LR4
jastutte
recently started hearing a relay behind the lower glove box clicking while driving. when the head lights are on and the relay clicks the headlights flicker very noticeably, almost like they are flashing.
could this this be relay R1 in the fuse box behind the lower glove box? i'm terrible at reading electrical plans and am struggling a bit to figure out what this relay does. anything else i should check while i'm in there?
Rover Range
Texas
The headlamp relay is in the engine compartment fuse box. Relay R11. Should be a mini relay.
jastutte
The headlamp relay is in the engine compartment fuel box. Relay R11. Should be a mini relay.
thanks. I just switched that relay with the one next to it for the rear heat. we'll see if there is a change. but, it really does sound as if the clicking relay is behind the lower glove box.
what does relay R1 control?
