replacing a rear blinker
sdigangi
does anyone know how to replace a rear blinker on a lr3? i can't get the casing off after removing the screws. is there a trick to that?
roverall
If you are reffering to the bulb, it just screws out from the back.
nwoods
Or, if you are referring to the whole light assembly, just pull straight back. Once you've removed the two screws holding it on, it just pulls out it's little plunger fittings. Then the bulbs are accessible from the rear of the assembly.
sdigangi
thanks for the advice. i was afraid to pull the casing off. i thought i would brake it. once i got it off it was a snap to fix.
thanks again
Sid1577
