Roof rack fairings
zulu
Do they help? If so, which one do you guys recommend? I notice when I have my roof bars up, there is a slight noise when driving on the highway.. looking for a solution. thanks
zulu
so...you saying that I need to wrap my bars in that material?:confused:
roverman
I don't know what neil is talking about, but I've heard about the "velcro trick" quieting the bars. IIRC, you put it under the bars to disrupt the airflow and stop it from whistling...
zulu
roverman: interesting. Because the bars are pretty smooth I can see the airflow travelling over the surface uninhibited and thus the whistling noise but with a rough surface like velcro that same airflow may be disrupted.. definitely take that into consideration.
On a different note, I looked at a Thule air deflector today (craigslist) but the brackets are way too small to fit over our wide roof bars of the LR. I guess I couldve mcgrubered a bracket that would fit but I thought I might be adding to noise problem if I didnt do it properly. The quest continues...
Neild
Neoprene around the front to work as a valence, sorts out the noise :biggrin:
Mr.BigsLR3
+1 This works, as does moving the front bar back a notch on the rails.
zulu
Thanks guys for the input..
Neild: now do I put the rack through the arms first or legs first of the wetsuit?:biggrin:
Neild
BOOM BOOM: He's here all week folks!! :biggrin::biggrin:
