Rotor button position
Gterry
I have a 1993 range rover and I changed the ignition module and pick up coil. I forgot to mark the position of the rotor button. What is the best way to find the right position.. Friends say the #1 piston needs to be at the top location. Can anyone one Help? Thanks
Confused... the rotor button can only go on one way it is slotted... did you remove the entire distributor? If so, TDC piston One.
Gterry
Yes I removed the distributor. TDC and the rotor on the #1 ?
Yes and yes.
STQAddie91
