Tabs on the Front Grill
T
txlr3
I was washing the new LR3 today and noticed two "tabs" inside the grill that look like they could be used to remove the front grill. Not wanting to do anything I couldn't undo, I decided to post before I played with this. Anyone know what these are?
Thanks.
Moose
Pics? Your guess sounds about right...
grommet
Yes, you are probably talking about the lower clips. There are 4 on top, 2 at the bottom. You can see the official instructions on removing the grill in your manual... under "Bulb Replacement."
N
NHESS81
lol...tabs...what ever happened to nuts and bolts, or heaven forbid screws...at least they didnt snap in two when you tried to remove things
S
schafari
The tabs on the plastic grill allow it to be removed in about 10 seconds. It is scary easy.
PE_in_UAE
