Thumping noise front - Drive shaft?
StevenC
I have a loud thumping noise from the front of my 2001 Discovery. I just replaced the brake calipers, pads and rotors on all four wheels. During test drives for bleeding the brake lines everything seemed fine. Within the first 20 miles or so after considering the job done a loud thumping started. It is coming from the front, it seems like the driver's side but I can't be sure. It is rhythmic and changes to match speed. I shifted to neutral while underway and the symptoms did not change. The vehicle sat in the garage for a few months while I was working on the brakes but the thumping is louder\stronger than a flat spot on a tire would cause. I parked it back in the garage immediately. A user on another rover forum recommended this forum and suggested it might be the front drive shaft. Is there a way to inspect or test to be sure without risking damage? Dive shafts are pricey so I would like to be more confident before ordering a new one.
Thanks.
Sid1577
