Trailer Lights not working
Mark Mason
Houston
hello, my trailer lights, cargo 12v plug and rear hatch lights are not working. Trying to find the correct fuse to check. Any suggestions or any ideas if not fuse?
Ricardowelch
1511 Willow Greene Drive
hello, my trailer lights, cargo 12v plug and rear hatch lights are not working. Visiting Autoguysland to find the answer what does it mean when your abs and traction control light comes on if you concern. Trying to find the correct fuse to check. Any suggestions or any ideas if not fuse?
According what i read on this forum, one person said:
"check the fuses in the Passenger Compartment fuse box.
Fuse# 6 is the TOW Reverse light
Fuse# 8 is the Trailer Pick-up Battery Feed
*Fuse# 14 is the Tow Side Marker Lamps. This is probably the culprit.
Fuse# 22 is the Trailer Pick-up (Ignition Feed)"
You can try checking these if it helps or not.
PE_in_UAE
