Transmission help!
MacDad77
:frown:
I'm sorry that this is the first time i have posted here. I have a 2000 Disco 2 with about 147k on the clock. today I changed the tranny fluid with a kit from Atlantic British. Just the pan gasket and filter which came with it's own two O rings. I drained the fluid which seemed discolored but not black or foul smelling. The car shifted fine before. I even had taken it off road in low range with no issues. I replaced the filter and fluid using Castrol Transmax Dexron/Mercon Domestic Multi-vehicle (ATF) Automatic Transmission Fluid that I got from Advance Auto. I used their select a vehicle function to match the fluid. I had the truck on ramps with the rear lifted and supported on jack stands. From what I could tell, the gtruck was level. I filled the pan until the fluid ran out using a piston transfer pump. I then capped the pan, started the truck put it in reverse to back it off the ramps (after removing the stands of course) and when level I checked the fuild by pulling the fill plug. and lots ran out. I didn't wait for it to stop. I capped it, shifted through the gears and rechecked the level. after which the fluid still ran out so I recapped it and tried to see if the vehicle wiuld move.
I had no gears. The low range lever was fine. I would gently rev it in gear, but nothing. I moved through all positions but nothing. tried low range, nothing. there is no noise what so ever. We got this car used but I have no idea how many previous owners. I don't believe all the dash lights work either by looking at the shop manual. :hmpf:
Could it be the pick up tube is misplaced? I attached it without difficulty. the three bolt went in with no problem, so I can't imagine it was misalligned.
I have searched some of the forums but can't find a simliar problem.
I feel completely distroyed here. After such a simple thing to do.
Someone please help!
Christian
MacDad77
Success!!
Thanks to all
(gotta pick up the youngest, will write more later)
rob bartleman
Have been reading through past posts, found yours.... and wondered what repair you needed to get your D running? All of a year has passed, but still interested!:hello:
davidsussex
