Warning Lights Questions
K
klark
I recently changed the brakes and calipers. Now the ABS, TC, and Hill Descent lights will not turn off. Any leads? Also Service Engine soon light is on. where is the shut off for that one?
Thanks
Y
yattalunga
hi,
check the ABS sensor wire lead near the wheel is connected to the senor ok. sounds like you may have bumped/damaged the lead. ABS/TC lights come come on. (having found it out the hard way).
cheers,
Yattalunga
davidsussex
