what is seafoam
basstard440
Great stuff, just be careful with it if you have high mileage or a questionable catalytic. Joe
Donjames911
Neither response answered the question 'What is Seafoam?' WTH is Seafoam?
It is basically a fuel injector cleaner, but can do more than that... kind of like marvel mystery oil... it does a lot of things. It is a product made of 100% petroleum so it will not hurt seals and such, and it works very well at many jobs. Kind or reminds me of WD-40 before they changed the formula.
Donjames911
Hmm, Marvel Mystery Oil always struck me as a product like aspirin, treats the symptoms but not the cause. What makes Seafoam better than, say, STP, for cleaning injectors? And I use WD-40 for a multitude of uses, what changed in the formula?
You can use any product you like for cleaning injectors, but for cleaning the valves via the vacuum tubes (direct cleaning of the intake) I have found Seafoam to do the job very well.
Personally I run Lucas top end injector cleaner in my Disco once a month and only use the seafoam about once a year.
Personally I would use WD-40 for any purpose, unless you are trying to displace water. It isn't a very good lube or penetrating oil, but this is just my opinions and should be taken as such. I am not a chemical engineer nor did I sleep in a Holiday Inn Express recently.
I stand corrected on the changing of the formula, (Yes I admit when I am wrong). I did some research and found that what I though was a change was just them buying up other companies. http://www.myfavoriteezines.com/articles/wd-40.html
And Yes I read more than just the above article, this one just read better then most. But it is still just a Water Displacer.
wolf
My opinion on WD40 - is stay away from it in a hi heat situation! Here's my ancedotal evidence against the stuff: about two decades back (1987) I was doing some work as an armorer and I was putting a beautiful old German MG34 (the world'd first, and in my opinion, still the best, general purpose belt-fed machine gun) through its paces. I had cleaned and lubed the gun and link belts, as prescribed in the German armorer's manuals, but I had used WD40 as the lubricant as opposed to good old fashioned standard gun oil or light machine oil. I let rip five linked belts (50 rounds per belt at 950 rpm goes very fast) - with no problem; then I went for extended defensive fire (sawed down a foot thick pine tee at one hundred yards) - for five hundred rounds and changed barrels (the receiver, bolt and barrel shroud were heating up nicely); then I went for another extended 500 round romp and I noticed that the gun's timing was starting to slow - I was down to about 650 - 600 rpm and I stopped shooting. I lifted the feed tray cover to find something akin to bubble gum - in long sticky strands all over the working mech. The WD40 had reached its limit and had turned to a new substance - a lot like bubble gum and just as sticky! Cleaning was not a lot of fun but I learned a valuable lesson - heat and WD40 do not mix well! So, I never use it on anything critical in my Landi or anything else for that matter
bloody lost
WD-40 rumour
I heard that WD-40 was initially used for aircraft de-icer....
Sid1577
