Will a LT230q transfer case fit a 94 Disco?
E
eric2
I'm looking to replace my noisy LT230t with a LT230q and I wanted to know if any modifications are needed to replace a t-case with a q-case or will it just go in? Thanks.
C
capthook
http://www.roversclub.org/docs/LT230Q_Transfer_Box_Manual.pdf
LT230Q X-fer box Manual, lots of info here. Also see
http://www.eastcoastrover.com/Discotech2.html
Gearbox / Transfer case removal w/ pics
" The LT230Q, whilst similar to the LT230T differs mainly in the following areas
Helix angle of gears increased 31 degrees together with an increase in the # of gear teeth, thus giving quieter running and an increase in power and transmission efficiency. Increased length mainshaft input gears together with increase thickness bearing housing & repositioned bearing. Redesigned intermediate gear bearings. Redesigned high gear bush giving quieter running"
hope this info helps!
-Capt
MrRodgers
