magicmarker
- Joined
- Apr 19, 2009
- Posts
- 7
- Reaction score
- 0
The driver's side of my heated windscreen doesn't work. Driver's side fuse is ok. Does anyone know how to test the element itself? Is it just a continuity check with a meter?
I live in California where it doesn't get cold enough to do an obvious ice clearing test... so I've not been able to confirm my heated windscreen actually works.
Can anyone suggest a test method to verify its working?
Thanks (in advance).
Karl.
Fogged windscreen should be a good test... Are you South?
I'm in San Jose. I should play more with the HVAC to see if I can get the heated windscreen to come on without the air as well (to separate out its operation).
Thanks.
Karl.
