DVD Player (Factory Fitted)
C
Craigb
Guest
Hi there, just got a new HSE with DVD in the rear. Do anyone know who makes these, I need to get a DVD HACK CODE to change it to Multi region. I am in UK so may be different?
joey
Most DVD installs here in the USA are aftermarket. I would either call a dealer or check with a local installer and see if they recongnize it.
C
Craigb
Guest
Thanks Joey, that will be my first point of call, but this was fitted by Land Rover. There is no brand name on it at all, but may need to duldge deeper!!
joey
Wish I could be more infomative on this issue.... but just not sure. A good pint of ale at the local pub with the LR mechanic may help in this issue :smile
Jamie Dasboroug
Hello Craig
I have the same question about changing the DVD system to multi-region. Did you have any luck back in 2005 finding the code to hack the system?
Jamie
GreyMatter
1.why does this forum have a quick reply if it NEVER WORKS?????????????
2. please explain to me this multinational dvd...cause i am in the USA and and every DVD works for me even the ones i got from the UK....hell even bootleg ones work....
Jamie Dasboroug
The factory mounted dvd player will only allow dvd's from a particular region, ie Region 1 for USA, Region 2 for Europe etc.
Your player by the sound of it is set to Region 0, ie will play anything from anywhere, ie is multi-regional.
My player was replaced by Land Rover under guarantee in Europe, but will not play European DVDs ....
joey
Slightly off topic, but greymatter the quick reply works fine... unless you are using Firefox, then it just goes to a black page, but it still posts you response.
GreyMatter
yeah im using firefox...i noticed it posted after i made a second attempt
