bjf
Are there any after market sensors that work? Don't feel like dropping another 190 on sensors.
It will NOT interfere with the hitch. I tow my boat with 265/65/18 using the factory removable hitch.
Correct, 31.5" will fit, specifically either 285/60-18 or 265/65-18 can fit but sometimes removing the fiber shield is also helpful to make it easier.
One must remember though that the original factory hitch is different from the 2nd design with the earlier protruding into the trite area more and having a longer shaft that also hangs lower.
The 2nd design was tucked slightly closed to the frame and set the 2" shaft a little further rearward. (I have both)
Of course they work, just have to use the same MHz frequency. Places like Discount tire will have these and match them to the year or vin.
Jwest, file the sensor?
I wouldn't alter the sensor at all. I'm saying file the wheel. It's just cast aluminum, no big deal to remove a little surface inside rim seat area.
g5k.
... with the earlier protruding into the trite area more and having a longer shaft that also hangs lower.
Jeepers hope this isn't a 'that's what she said' for the poor 2nd design and unsure what to make of you having both
bjf
My shop that installed the tires is going to install them for free. I know any with same frequency will work but I was asking if there was one in particular that works with these wheels. The original ones I had do not fit.
There were a couple typos in my post. The old design protrudes into 'tire' area more.
However, to your post, no, the new design is much better than original.
g5k.
Sorry mate my attempt at humour :)
mpinco
New or old design, they both suck for stowing larger tires and needing to tow.
They are perfectly fine for towing but the newer design isn't as low to the ground which is an improvement.
Tires of size larger than 31-31.5" don't belong under there anyway so it's pretty much a deadend arguement IMO.
