Hill descent control
Frank8
Vermont
this AM I engaged the HDC as usual going down a long steep road.
It made a growling sound and felt jerky.
Never did this before.
Should I worry?
Pfunk951
Elaborate please.
In HDC, the gas and brake pedals can be pronounced making it feel jerky.. I'm pretty sure it uses ABS braking to control this..
Growling- meaning whining? Could be the ABS activating.. And depending on your speed, this too could be acceptable IF you are in a lower gear (drivetrain noise).
All bets are off if you are talking about metallic crunching and slapping. Or, a really loud howl like a spider monkey high on angel dust trying to escape from under your center console- it could be something in the TC or transmission..
Let us know..
Mike
Idaho
... really loud howl like a spider monkey high on angel dust trying to escape from under your center console...
Mike, that was awesome. I need to remember that line.
:D
blainerides
Seattle
What is the status of your pads and rotors? If they’re getting close to the end of their life, the HDC gets groanier (that’s totally a word, right?) and groanier. Replace them, and it works quieter (normal, light groans). I have no idea the reason for this, but maybe the worn/thinner pads just vibrate more?
Frank8
Vermont
Just had the state inspection done. Rear pads are 4mm.
The groaning/shuddering has decreased markedly but it still is sometimes there.
There’s no metal/metal screeching or grinding, just the low pitch groan and shudder.
Bethesda, Maryland, USA
Does it happen when you adjust your speed of HDC using the cruise control +/- set buttons on your steering wheel?
Waterndirt
Should I worry?
How fast are you going when you engage the HDC?
Usually around 15-20
You answered one of my questions. I thought you might be engaging HDC at too high of a speed (max is 50mph for engaging it) but that's clearly not it. Does it make sounds if you come to a full stop and then engage HDC?
Does it happen under any other braking situations in normal driving?
