2012 LR4 V-8 vs 2015 LR4 V-6 Quirks
D Morgan
Richmond, VA
Ok, was going to buy 15' V-6, but heard the negative comments regarding the performance. I drove one for 10 days, highway and city, found the acceleration to be fine. Not quite as fast as the V-8, but certainly more than adequate. Did not do any off-roading. Waited on a title and while waiting took it into a LR Dealer for evaluation. The tech said it "sandcrabbed" when turning into his service bay, indicating a future t-case issue. Also, check eng light, needed t-stat, stuck open. Also, air suspension faults stored. That stopped the sale. I was surprised to hear all of this at 59,000 miles. The previous owner just replaced the t-chain and coolant pipe at 57k due to rattle at start up. That cost 6k. The Carfax checked out great, no accidents. This Rover sounded like it was going to be a tech's best friend. So I passed on it.
One of the "quirks" I did not like was the constant beeping from the rear parking sensors as soon as it was put into reverse (in open area) until you manually cut it off or shifted to drive. Another annoying feature was the auto stop/start. Even on hot days in the low 90's and high humidity, it still cut off at stoplights. Super annoying. You have to select Gravel road setting to override. The info screen has too many icons that are smaller, kind of confusing while driving. Otherwise, I did not see anything I could not live with, other than having to spend about $5k right off the bat. So, I ended up purchasing a super clean 12' LR4, that is a little simpler in screen layout and has 110k on it, but was well maintained.
The nav is outdated, but I use waze anyway. It does have the Xenon headlights, which are nice. The V-8 is very quick and powerful. I had it checked out as well, LR Dealer found nothing in need of immediate repair, so I pulled the trigger on that one. I would highly advise having a dealer or experienced Rover shop check out your purchase. I would not have caught the weak t-case on the 15' model until probably 3 months into owning it. Best $ ever spent. Hope this helps with purchase decisions. Again, the V-6 wouldn't scare me away, the later models just have the annoying updated features you don't need.
PaulLR3
Boston
^Agree...good choice on your part. Always better to get a well maintained LR4 even if it has higher mileage.
FWIW, you can adjust the volume of the rear parking sensors. When in reverse and beeping, use the radio volume to change the parking sensor volume.
TrinidadLR4
NE Washington DC
Sounds like you made a better choice. The v8 is great and that auto stop/start feature is beyond annoying. Out of curiosity, did they elaborate on the sandcrab comment? Would like to know what that entails so as to watch out for it. Did the 15 have the HD pack?
sandcrabbed? meaning the tire skip at full lock? I thought all LR4's did that naturally...
Mine does this very occasionally but not all of the time. My transfer case was replaced a while back due to it making metal shavings, but nothing changed after the new one was put in.
Nechaken
That sounds like a malfunction. It should be quiet unless there's something close to the sensors....
D Morgan
Richmond, VA
Tight turning as in a U-turn. My 12' does not do that. I checked it before buying.
The only drawback I have with th 12' is it does not have a rear view camera. Above the lic plate, there is a blank, apparently never equipped. Would be nice to have.
Haven't investigated aftermarket system, but from those I've seen, looks like a Garmin stuck to the w/s, don't want that.
Anyone else dealt with this?
jlach993
Fresh Meadows Queens NY
yeah mine does it when the surface is freshly asphalted, wet, or with sand/gravel like a construction site. Besides the shavings in the transfer case, was there any other reasons why it was replaced? I wanna keep an eye out for signs..
jlach993
yeah certain tires do it. stock contis that came factory never did it. full lock u turn on cooper zeons caused skipping. Then the vredestein or however you spell it that replaced those coops were like the contis as well.
