1996 LandRover Discovery Overheating
T
top222
What Could it possibly Be, it overheats BUT i get NO heat inside the car, after the car gets warm the water boils in the Water tank were u pour water in, and when you open its sprays water
skyguy
Maybe we should let our trucks mate. Mine is frozen solid lol.
Good luck with your truck. Check for a hose that is weak as it may be collapsing and causing a blockage
whiskeynipple
enginge thermastat?
bad heater core?
thers a thermastat in the heater core... right?
I would say thermostat or low on coolant. Remember if you overheat to many times you will need a new engine... aluminum engines do not like being overheated.
R
royw
my truck water boils out but does not over heat replaced waterpump , cap ,radtor removed thermostat can not find what it is
Hang on, you say you have replaced the water pump, the radiator cap, the radiator? and removed the thermostat and it still boils over?
Give us some history on this vehicle what has been done, mileage, year, and what if anything has happened prior to it boiling over.
Did you run the vehicle long after it boiled over? Or did you shut it down ASAP?
Vintage99
