B
bombardier
I posted a while back about codes on O2s and MAF on my 2003 disco with 23k miles. runs beautifully...i took it to the dealer and they found a mouse nest in the truck and thinks they may have munched wires. which means not covered by warranty. he said it looks to be an electrical problem however all wires look fine...but the wire harness runs through the intake mani and needs to be removed for inspection. At about $700 for labor will most likely end up not finding anything i told him not to go forward.
I'd like to take the disco to another rover in hopes of getting work covered by warranty..but if they share info they will obviously see the findings of the local shop. so, does anyone know if dearlership systems are linked?
note: luckily i have a local independent rover tech who i met with, and the guy is awesome. from his equipment (has all LR certified diagnostic equipment) he tends to think there is no problem with wires and could just be O2s etc...which is obviously warranty work. so basically because one dealership most likely misdiagnosed a problem i could be screwed out of warranty covered work.
