Hi all,
I recently joined the forum after picking up a new LR4 HSE this winter. Love all the great info I'm finding on this site, so thought I'd throw a couple questions out there.
So I just installed a hitch mount bike rack (Kuat NV) and have a couple quick questions.
1) Is there any way to turn off the rear parking sensor or at least turn down the volume? With the rack installed, now whenever I backup I have to listen to the steady warning tone of impending doom. I went through the manual and found there is a parking sensor button next to the harards button. I however do not seem to have the option that gets me this button. I also read the sensor will be deactivated when trailer cables are hooked up. As I only have the receiver, I do not have any cables to connect.
2) For those of you with the quick release tow hitch installed, should there be a little side to side movement with this hitch? The rack is rock solid in the receiver, but there is some movement with the hitch itself. Wanted to see if this is normal or if I should take apart and reinstall (dealer originally installed).
Thanks for the help!
