Brake Switch didnt help, Brake Bulbs didnt help...What Next??
roverman
Good point about charging system. 116,000 could easily be time for the alternator to go. When mine started to go about 105,000, faults flew all over the place.
Tstroh
No I havent, should I? The battery was no good when I was buying it so they got one directly from LR.
You have to take it to the dealer pretty much. An IIDTool is keyed to a particular VIN.
roverman
Take it to the dealer for what? Pretty much any mechanic can check the charging system.
He asked about reading codes. I meant take it to the dealer for a code reading absent of an IIDTool or Faultmate in his possession.
drew
If you can fork out around $200, you can get an iCarsoft diagnostic tool that will read all of the modules for you. It will allow you to work on your own brakes as well.
