Cooper Zeon LTZ ?
drzjoint
I am getting the Coopers installed tomarrow. :thrasher:
What psi. are you running on the road?
On the stock tires I was airing down to 25-20psi on the trail, Have been as low as 18psi. That was with my Avons in a 255-60-18.
What are you running on the trail with the Zeon?
nwoods
On road, in high mileage or heavy load config, I run 42PSI, but its a bit stiff. For pleasurable road and ride handling, 38PSI is great.
Off road, generally around 26-28psi. About 18PSI in sand. I can't air these Coopers down as much as the Nittos because they are softer all around.
jimbiram
Ditto for me with the Coopers. The lowest I dropped them is 25 in rocky terrain. Most of the time I drive 5 psi above factory spec for front/rear.
drzjoint
I'll probably set my stauns for 26-27psi. that should get me to where I need to be.
THANKS
nwoods
Just hit 30,000 on them this weekend. I should get at least 40k and probably more, possibly 45k based on current wear.
jimbiram
Same for me...30k...had to replace one due to bolt on the freeway through the tread near the edge.
Boaz
40 front and 42 rear for a good balance of mileage and ride on the road. 28 off road seems to be enough. Hope you like them!
