Gents,
For the guys with Anthracite Compo's, where did you get centercaps for your wheels?
J
I have 265/65/18 compo spare, heatshield off, slightly deflated, tow receiver is not an issue. It's tight against the back of the receiver but the hitch goes in fine.
Sent from my Nexus 6 using Tapatalk
No problem. That's the same conclusion I came to–the various compromises and headaches weren't worth a 0.5" lift to me.
No that's incorrect. When going from a standard load (SL) tire to D or E-load rated tire you have to increase pressures for a given load because of the construction of the tire. The heavier construction necessitates higher pressures to maintain the physical form of the heavier, stiffer construction of the tire. In other words, they need more pressure to keep the sidewalls from flexing too much and creating excessive, tire damaging heat at speed. The tire shop said their rule of thumb is 8psi per additional ply. I didn't like that "rule of thumb" so I did some actual calculations. See my post #378 above.
An article on the subject from FourWheeler: http://www.fourwheeler.com/how-to/wheels-tires/1407-understanding-tire-load-ratings/
"When comparing tires that are the same size/same internal static air volume but have different load ranges, one with a higher load range at higher air pressures actually may have a lower LCC. For example, a P275/65R18 can have a 2,500-pound maximum LCC at 35 psi, whereas an LT275/65R18/C (six-ply rated) might only have a 1,948-pound capacity at its maximum 50 psi. The difference: P versus LT."
Also see the example on page 11 of this Toyo document: https://toyotires2-1524598101.netdn...ication_of_Load_Inflation_Tables_20151020.pdf
Hello Dan,Thanks, bullmkt, I had new 265/60R18 KO2s mounted yesterday and the Discount Tire guys didn't really have a clue about the PSI. I thought I remembered a discussion of this on the forum and am glad I found it this morning. I'm going to run mine up to around 50. I'm just trying to decide how much to offset the front from the rear.
BTW, I really hope that your "handle" becomes true over the next few months. January was a very painful month! ;-)
Thanks for providing this information to Dan, it also helps me. I think I really need to get my LR4 weighed and see how heavy it is with the modifications. In checking my tire pressure this morning, I made a slight adjustment to the front tires because they seemed slightly under-inflated at 47 psi (based on chalk test and drive), so I increased to 51 psi and the rear is still at 51 psi. I know I have heard of others with modifications running all 4 tires at the same pressure, but not sure if it's most appropriate. I really think I need to be running above 50 psi for all tires, but still trying to figure out the sweet spot. I'll get a weight and then run the calculations you describe in your post.No problem Dan. When I first installed the tires I inflated them to the 44psi front 51psi rear I had calculated, but backed off a couple psi because it was riding really rough. Since then, the tires must have broken in through heat cycles and mechanical load, because I have them back up to 44psi front and 51psi rear and the ride is great. For others reading, those pressures are based on a stock LR4, so if you're loaded up with off-road gear and/or towing, you'll have to run the calcs for higher pressures. See post 378.
On the market, yes it's been a dreadful start to the year, but I'm beginning to feel a little more confident now. Oil seems to be stabilizing and hopefully it sticks.
Hello Dan,Drove up into the "foothills" today to try out the KO2s. I inflated them to 46/50-ish (may have been 51 as my gauge is analog and not that easy to read). I drove 65-70 on the interstate. 55-65 on a fair bit of "highway" then did a bit of offloading including some snow and ice work. (See below)
I love the tires. To be honest, they did not "feel" that harsh at those pressures. My wife an I didn't even notice the tires and for the past 4 months we have been running Nokian snow tires that, with the 60-degree weather we have been getting, are probably a bit soft. I might bump up the front a bit after I get my sliders on tomorrow. And I'll increase the rears to maybe 55 when towing this summer. But I have not done any scientific tests. I am simply going off of what bullmrkt and Finlayforprez do and land somewhere in between. I expect David's LR4 is a fair bit heavier than bullmrkt's!
In the picture below I am about to enter a very shallow stream. The trick was that both banks consisted not of rock but an ice shelf. So I need the tires to "climb" the ice or at least get enough push from the tires in the stream. The ice shelf that you can't see, the closest one, was about 8-9" high. When I hit the shelf the tires spun for about 1 second and then I was up, out and through. By the way, 20' to the left of the picture there was a bridge I could have used. But that wouldn't have tested the tires.
