ground clearance
SoCalPaul
For me, most valuable mods are E-rated tires (265/65), then Sliders (I use Tactical), then gas tank skid. Gas tank is the lowest point and very large..I've heard a few stories of people denting them and reducing their range to 150 miles per tank.
I get over things like this by using the sliders...
wayne
Been a long time since I posted on my LR4 development. It now has a low profile roof rack, rear ladder, under carriage protection, including the compressor and rock sliders; these items were all from Prospeed in UK. The roof rack has mounts for petrol cans, spare tires and sand ladders. I added a 9500 lb Warn winch with factory install, and a LLAMs height control from Australia. Next will be new 18'' wheels and BFG tires. She's getting pretty serious, but I am still nervous about the ground clearance under the control arms.
Cheers
Wayne
iSurfvilano
North Beach, FL
Cheers
Wayne
Please post some pics!
jwest
Seattle WA
Cheers
Wayne
You probably know but it requires a different driving approach from older solid axle offset differential vehicles where you'd have more clearance near the wheels but much less in the middle near diffs and break-over depths.
Compare clearances along the middle between lr3 + LLAMS temporary lift on 32" tires vs D2 with 35" tires....
I roll up next to lifted Jeeps here all the time and they're on 35-37 but their differential is sometimes lower than where mine can reach. Yet mine is also fantastic to drive 45 hrs cross the USA at maximum hwy speeds.... 36" tire - 18" centerline - 5" for a 10" diff = 13" clear ground clearance at the axle ... I've measured mine under the engine plate at 14".... ;) Even 12" at the rear with the ASFIR diff skid which also covers the exhaust.
jwest
Seattle WA
it's 20lbs or so being 5/16 steel... direct ASFIR usa Had to custom bend 13 sections to work with the Magnaflow which was super annoying but hasn't made noise against anything yet.
I can verify and send a photo if you need. It's still off from all the suspension work I did. Pretty sure whole rear end could sit on a rock without really damaging it.
