Hella Wiring
JJMyerz
Adventurer
So the previous owner of this land rover was an idiot. The wiring for the hellas was just wrapped around each other and the battery :stupid:
Oh and he drilled 3 holes in the dash for one set of lights...guess he didn't notice the stock factory switches??
Anyway, I would like to wire these hellas into the factory switch on either of the switches. Is there a diagram on how to achieve this?
Thanks
Justin
Sergei
Justin - there is easier way :) Just grab heavy duty wiring loom, hook lamps up & etc. Then there is positive lead that actually switching relay. You can wire-tap it into 10A fuse on standard fuse box (there are 4 that controls lights - in vertical one. Depending how you like it to go up - with high beams or with low beams you need to tap into one of those - its pretty easy to check. Or if you want high ones i can go and lookup which one i used). That way you dont even need any extra switches (will fire up with regular stalk switch) and all you need to go into cabin - single wire.
Cheers
Sergei
Disco2TrailEdit4
