jwest
Best batteries I’ve ever had after years of Optima deep cycle not even holding up long enough: Odessey deep cycle. For Lr3 factory slot, 1750 fits perfectly.
It May also drop right in to the house battery location but you can modify the box by relocating the pump forward and get the biggest Odessey possible in there 2150 if you also approach the terminals laterally instead of from top. Stud has to be cut down a little too.
My lr3 sits often when out of town or just using the other cars more and the 2150 has been in 10 yrs with 1750 in starting position about 3-4 yrs now.
Also use “hunting” mode for interior lights if opening car a lot without running it. Lights stay off then unless manually turned on-just don’t forget to turn off as well !
