Leaky Windsheild??
C
Cat
Leaky Windshield??
I have just discovered that while driving during heavy rains, I have leaks at top corners of front windshield on both sides. Has anyone experienced like problem/s? If so, has appropriate resolution been found/made for your problem...
Return to the dealer and have it fixed under warrenty....
R
RadRocker
Bummer! Get it fixed like Joey says. Very strange design problem indeed.
How fast do you drive?
C
conerly
Dealer had one in for the windshield when I bought
There was a white LR3 in when I was test driving with a leak in the wind sheild. Dealer was fixing.
Good Luck
C
Cat
Thanks for the headsup, guys... I am heading for dealership asap... if anyone else has any input, it would be greatly appreciated...
T
tzucc
I have driven through some pretty hard rain lately and had absolutely no leaks in the front windshield or anywhere else for that matter. Incredible. Absolutely a dealer warranty fix.
O
Outrageous
Have them check the drains for the sunroof. And please report back about what the fix was.
madtownrover
Good idea...my sunroof drain had something lodged in it and the first heavy rain resulted in a wet dashboard ;-(
Blew out the drains with an air compressor...no problems since then.
O
Outrageous
If you open the sunroof and look around the periphery, you should be able to see holes for water to drain. These holes are connected to tubes which are routed down the A or B pillars (not sure on the LR3) to exit safely under the car.
