LR3 Suspension Lift
alex1orr
I am wanting to put an aftermarket suspension lift on my 2005 lr3?????i cant find a company who produces one??? any ideas?
nwoods
Sorry, such a thing does not exist for an air suspended LR3. There are some spring sets for coilover based LR3's (such as mine), including King, Peddars, and OME, but none of them replace the airbags, nor should they. The articulation and ride quality of the air shocks is superior.
However, you can fiddle with your level sensors and get and inch or two more lift, permanently, if you wish.
http://www.lrrforums.com/showthread.php?t=5192
drzjoint
I use the sensor arm modification I gain 2" in all settings. Works well. I CAN MAKE YOU A SET. They are an easy swap I dont even have to take off the tires and can do it in 15 min or less.
duckdive
Does anybody know if an aftermarket height sensor exists??
Some local indy LR shops have figured out the calibration numbers and are starting to modify suspension height via software (IDS). Here in L.A. for example, West Coast Rovers will raise - or lower - your LR3/RRS to whatever height you want for a couple of hours of labor charge. The calibration carries through the entire range of height modes.
drz, I sent you a PM on this topic. Thanks in advance.
drzjoint
Who else is running this? The sensor arm mod. I went with 12mm 2.5" of lift
what are you guys running. I have thought of trying 13 or 14mm to get 3" of lift.
richpike
Can they go more than the 1" or so that I've heard about? Is it then fixed at that height? Or does the air suspension levels (access, normal, off road) still apply?
-Rich
Randall
i took only 10mm off all around i never did like a before and after measurement but its nice and best of all (if you do it yourself) FREE!
dry_fly
Anyone out there with the Sensor swap still use thier truck for towing? Any side effects to be aware of? Thx
