catman
I am not so sure about that, my guess is that most "Poverty spec" Disco SEs will arrive with the EAS option pre-installed here. It's strange they are offering coilers at all in NAS models. In most other markets abroad, UK and Eurpoean countries included, electronic air suspensions are standard equipment on all new Discos, including barebone S trims with cloth seats that aren't even offered here in North America. It was probably done so they could advertise it as "starting under $50K", but I don't think there will be that many coilers on dealers' lots to choose from next year.
Strange, I just had an alignment done on my LR3 and in looking around for specs I came across this post, which many of you may have seen in the past:
57.65.04 1.80 W6 ALGN4W
Normal warranty policy and procedures apply.
REPAIR PROCEDURE
ALIGN SUSPENSION GEOMETRY
1. If the vehicle has Electronic Air Suspension (EAS), refer to Technical Bulletin LA204-007, connect IDS to the vehicle and place the Electronic Air Suspension (EAS), into “tight tolerance” geometry setting mode.
NOTE: A small number of coil sprung vehicles were imported into North America at the very start of LR3 importation. Step 2 is included in the event that such a vehicle requires suspension alignment.
2. If the vehicle has coil spring suspension, perform the following steps to ensure that the equivalent of a full tank of gasoline weight is present in the vehicle when the alignment process is performed:
REPAIR PROCEDURE
