Thx Joey. Checked both fuses. Heat or A/C still will not come on. I'll look at the switch to see how I can clean it (why does the key need to be out ?)Welcome to the forum...
Have you checked both fuses 12 and 34?
When did it stop working? Does it work with heat on and not A/C? Could be a dirty switch, have you tried using contact cleaner and spraying it into the switch (with the key out of the ignition that is.)
