D
dmorro83
The other day the temperature gauge on my discovery started rising.(this is the first time it has ever happened) Upon noticing this I cut it off and lifted the hood and found that it was low on coolant. I filled it up to the level on the coolant bottle and noticed that I had to fill it up several more times after I ran it that day in my driveway. The temperature has not risen again above normal level since that day(although I have been very careful driving it the past couple of days)
No fluid is coming out under the vehicle, no noticible white smoke, no noticible fluid in the oil or vice versa
The past two days the fluid level has been normal with no temperature rise.
I have noticed for a while now the gurgling water sound from under the dash.
As far as bleeding the coolant system, how do you exactly do that? I see the bleeder screw on top of the hose over the radiator.
Any suggestions please help!!! I hope it is nothing serious
Thanks,
Drew
2000 Discovery
125,000 miles
Thanks,
Drew
2000 Discovery
125,000 miles
