SRS Module replacement?
Maddie
Wow now I know what II RC means I left a post asking about abbreviations in the chat. PS use petrolium jelly on those battery terminals. It keeps them from corrosion a little tip I learned from my rover manual . Make sure not to use oil!!! Petrolium jelly only!!!!!!
dlrnzo
Is this crazy or am I? Dealer wants over $3000 for the SRS control module!. Just part, not labor. I checked the wiring the best I can. Cleaned off the battery posts and connectors. Is there any way I could get a used module and intall it myself? Would I need a dealer to do anything? Thats nuts!
Disco Mike
Get both termanils cleaned and tightened, then go see a shop with the proper scanner and have the codes read and cleared.
Bad or low voltage will throw a fault code on the SRS.
dlrnzo
OK, Ill give the dealer a shot at reading the codes and clearing it. Its going to cost me but its propably worth a shot.
Thanks
Disco Mike
Do your cable stuff before you go to a dealer, other wise they will charge you $100 plus to tell you the same thing. Get back to us after wards with their estimate, remember you can buy good guaranteed used parts for a lot less money, if needed.
dlrnzo
Understood.
If I buy used, is it 'plug and play' like DIY or do I still need a dealer to get it in?
dlrnzo
Ok, some results finally.
Dealer stated that I need a new ecu for the SRS. Also stated that a tensioner for one of the belts was acting up. Sent some lube or gel in there and seems fine. I do still need the ECU. Got a number of $770? Sounds big but was expecting worse.
Maddie
Isn't that precious first the stealersships wanted $3000 now they want $770? Why the discrepency?
Maddie
Sow was it 700 bucks or three thousand and some change?
