ok, I can not get this idle under control
the first problem I had will have to wait, idle has a mind of it's own
here is the score
new parts are as follows;
MAF sensor
coil pac
VSS
injector #4
throttle position sensor
idle air control stepper motor
crank position sensor
camshaft position sensor
I installed a PCV rebuild kit complete
fuel filter
fuel regulator
I checked the pressure on the rail, all good
I checked compression, all good
I have done the sea foam thing(tank, crank, intake) 3 times
I pulled the connector off of MAF, still whacked out idle and about 2k rpm issues as at first
so
I pulled off all sensors multiplugs and went for a drive, same problem as I started out with, until the TPS went to shut off, WOW
ok, new stuff I have seen
when pulling a grade, the original prob is relevant in all gears, push in clutch and give it a rev, feels like a 4 cylinder
let it catch itself, then it goes back to normal
ok, here is the strange part(yup)
level driving, at about 50mph, 4th gear, it will run like it is missing a clyinder or two, let off on the gas, wait a second, then give it gas, it is all good, then, it will go away again and start missing, what do know about the main brain failing on these?
the problem seems to ocillate, comes and goes at speed
the idle, however, is way whacked
idleing way high, I disconnect the TPS, the idle drops and then goes way high
I plug another TPS not attached to the vehicle, idle goes to where it should be, so I take off the one attached to the vehicle, the idle goes down to normal, until I move it to where it needs to be for the screws, then 2500, to 3000rpm
I hope any of this helps, but my fixes are not fixing anything, the idle air control, connected or not, changes nothing, however, if I take my spare, hook it up while the engine is running, hold it in my hand, I can feel it searching
I can start the thing, It always starts
and I can walk away and hear the idle going up and down
when I sit inside while the thing is idleing, hand on shifter, I can feel it run true, then start missing, then run true, then start missing
knock sensors? ECU?
I does not like a load, going up a hill, forget it, push in the clutch and give it a rev, sounds like multiple thuds
sorry about my questions, but this is not working out like it should
the stereo sounds fantastic, 2 tweeters, 4 mids, 2 subs with an amp, and a 6cd changer, on a positive note
p.s. no walking so far, knock on wood
