Hey all,
After off-roading out here in the south west and hitting Moab this past weekend, I'm considering adding some rock sliders. Even though careful wheel placement has been key to not needing them until now, I have a feeling that moment may be getting closer.
It seems that the general consensus is that the Terrafirma ones are the way to go.
I believe that I have read that you need to install foam in order for them not to squeak... How does it handle fording water? Do they provide the foam?
I've had to replace my air compressor a while ago and have the new design that requires relocation in order to fit the sliders. How much additional work is this? How easy or difficult is it to accomplish?
Overall how many hours does it take to do the install?
Also do you recommend the nerf bars?
As anyone considered going the Prospeed (UK) route?
Thank you
Axel
Hi Axel,
I think you mean Tactical 4x4? They are not hard to install, but you will need to lift the compressor. Tactical supplies you with a bracket which works fine. The only issue (and it's not a big deal to me) is that the compressor is closer to the floor boards and is quite a bit loader when it runs. As for the install, it's likely just 2-3 hours or so. I do recommend putting heavy foam/rubber anywhere that the slider touches the body or you will have creaking (which is annoying). These sliders offer great protection, but are quite heavy. Expect some MPG loss and you may feel the extra weight when going around corners, etc.
As for nerf bars, they only protrude a little and have not been an issue at all. I would go with it, as they actually provide a bit more protection. I have a lot of scrapes on mine that saved me a few times. Plus, you can use them as a jacking point.
Let me know it you have any questions. I have seen the ProSpeed, but again, I don't think they offer the level or protection of the Tactical 4x4.
Regards, David
