So here's my issue: my 06 rrs sc has thrown all kinds of warnings, transmission fault limited gears, transmission fault reduced traction, park brake fault, check engine light, hdc fault, no special programs, suspension fault, srs light, abs light, F in the gear selection instead of D, DRS light on , fluctuating idle and stalls. i need a MAF sensor and a new thermostat, that i know. I took it to an independent garage that works on them. The list of codes it pulled are astounding, at least 75 codes. I am at a loss i'm hoping its something like my battery. i can't imagine it all going at once.
Any input would be greatly appreciated . the codes :
Engine: P0102, PO217
Trans:U2023
Trans manual:0562, P173A, P0915, P1811, P1807, P826, U0100, U0I55, U0101, U0138, U186D, U1A03
ALL TERRAIN:U0100, U0402, U0416, U0403, U0421
CLUSTER:U0010, U0100, UO132, U0182, U0164,U0159, U0127, U0138, U0184, B1A77, B1A76, B1A87
ABS:U0401, U0403
AIRBAG:BIA00, B0095
DRC:C1119, U0100
RIDE LEVEL CONTROL:C1A28, C1A36, C1A18, U0416, U0100, U1A13, U0136, UO434
LIGHTING MODULE;B1D66, B1D67,U3000, U1A38, U1A39, UD100
HVAC:B1B70, B1B70,B1B74, B1B75, B1B76, B1B78, B1B82, B1B83
PARK BRAKE:U3FF0(INVALID CODE)
AND MORE
Trans:U2023
ABS:U0401, U0403
AIRBAG:BIA00, B0095
DRC:C1119, U0100
AND MORE
