Transmission oil
Azughaibi
Saudia Arabia
Hi everyone
I would like to ask about transmission oil for LR2 2009
1- How to check the level of the oil because I have leaking?
2- How to change transmission oil for this model?
Thanks all
Ali
SoCalLR2
Northridge, CA
There is two-part screw in the bottom of the transmission, underneath the car. If you take the center screw out and no oil comes out,then it is low. If a small stream comes out, it is at the proper level. You need an adapter and a pump of some sort to add transmission oil.
