Chrischris70
- Joined
- Aug 9, 2015
- Posts
- 11
- Reaction score
- 0
01 Disco 2 4.0: More or less messed up my transmission today. Well, more; just not quite sure what in it is messed up. Ill provide the story as to how I messed it up ( just to help with an idea) then provide the symptoms. I have an RV, a 30 foot rv which was loaded down (weighing probably 15k lbs) and stuck. I had no choice to use my rover to snach it from its hole. After about 8 (hard) snatches I freed it up. Here's the fun part. After the snatches and after id unhooked my truck, it had a funny noise. The sound is like a whiring sound when in neutral/park, but when in gear with my foot on the break is feels kind of like gears slightly rubbing together, as in the teeth just barely touching at a very low rpm. The truck is still driveable but has me very nervous, as I don't have very much experience with transmissions. I am very mechanically capable so this isnt a huge issue, though I may not know each term. If I do not know something I will figure out what it is. I feel like I may have of stripped something on the inside or broken something loose. I plan on soon checking/changing the fluid soon, but haven't had a chance as this all happened two hours ago.
Edit: transmission was in 4low when I yanked, yet it is still prevalent in 4high. It leads me to thing something to do with the torque converter, or where the transmission connects to the t case
