F
fbrems
Hey All.... Well it sounds probably a bit unusual, but I relined my 4 brake rotors without taking them off. (Depend how much they are damaged) Jack up one wheel, remove de wheel and block the others to avoid motion. Then start the engine in Drive and let spin the lifted wheel. I use a disc for metal (which you fit on a grinding machine) and start grinding the rotor with "coarse" first. Believe me the rotors get polished smooth as new and finally you finish with "fine grade" It does not take long to reach an even surface, job done and next one to follow. Not everything has to be by the book or dealers advise.
