Upper fuse box
Daveykid
Supporting Member
Supporting Member
Chicago
Interesting... I had no idea there's a fuse box behind the upper glove box. That would be THE worst place to put one, because it's hard as h-e-c-k to get to.
I've personally opened it up and there's nothing back there on my '11 LR4. Here's an electrical wiring diagram of mine and it's pretty true to it, well at least for me.
I used this site.
Lr4KP
North Carolina
This is what my gap tells me
Lr4KP
North Carolina
Could be anything.
You would need to check which module for the infotainment system is off line .
The modules communicate with each other via a fiber optic cable.
There are fiber optic bypass loops that you can buy and just eliminate one by one.
ie: unplug the audio amplifier, install the bypass loop. If the infotainment screen comes up, amplifier is bad.
I forgot to mention also I was getting parking brake faults but they went away the next day and i was able to clear them out
Lr4KP
North Carolina
Could be anything.
Please forgive my ignorance
Could be anything.
im still trying to figure this one out. I have sent off my radio and there is nothing wrong with the radio. I bought the bypass loop you mentioned and checked the amp it still nothing. Where should I look next?
Rover Range
Texas
There are two more modules in the right rear panel, just behind the 2nd row seats.
When you install the bypass loop, cycle the key off and on.
A module that is on line will have a red light on where the fiber optic loop plugs in.
In the past, customers have decided it's cheaper to buy the bypass loop than spend money on a satellite module.
Lr4KP
North Carolina
I plugged my bypass loop in both of those and nothing changed.
Rover Range
Texas
Can you post your VIN # ?
I'll check and see how many modules are on your fiber optic network.
Thanks
Lr4KP
North Carolina
SALAM2D49AA546558
Also when I check my fuses with a test light the radio fuse doesn’t have any power to it
