LR3 Thermostat Location / Difficulty to Access?
shelbyjett
Hi, my thermostat is stuck open on my LR3. Could someone tell me where it is and the degree of difficulty to get to it (ie will I have to remove a lot of other components to switch it out with a new one).
Many Thanks!
Shelby
TRD4ME
Right under the engine cover. You will have to rebuild it, it is not a one peice thermostat. It is inside a small manifold with four bolts holing it on. Usualy what happens is the O-ring seal around the inner plate creases.
Sid1577
