2006 Range Rover front bumper removal help
Greg Schroeder
Hello,
I've given it a go for a couple days now, searching forums, the internet, youtube and such to try and find a front bumper removal guide for my 2006 Range Rover HSE L322. Could anyone please guide me to the instructions? I'd greatly appreciate it.
confirmer
A pal of mine has also the same dilemma, what he did but to have it done by an expert. Its quite expensive though.
Greg Schroeder
I guess that's one way.
I did gather an expanded image of the parts and did the job myself by studying the assembly. I just wanted to re aline my bumper, headlights and grill so it looked fresh. My hope was that of all the people on this forum one might have a procedure list for accuracy purposes. No big deal though. I understand many people would prefer the convenience of dropping the car off for a few days, drive to pick it up, pay the 1600 dollar bill (quote I had) and be done.
I ended up spending sixty cents for some washers and doing it myself in an hour and a half. :wink:
confirmer
That good to hear. I hope you were able to doc the entire assembly as a reference to other. Good by the way.
Greg Schroeder
The screws which I loosened and tightened are as follows. I'm still uncertain of a technical detail which would be ideal however this is what I found. My write up probably shouldn't be taken as fact, but only as a point of consideration to be included with personal evaluation.
Grill - A few screws on top then lift out the grill. Pull the grill up and off. There is a sensor on a wire which is removed and replaced later at time of assembly.
Bumper - 2 in the front, 4 on top. The original design seems to look like the bumper will be in correct location naturally as the screws don't pinch the mounting tabs firmly. I put washers on the screws to allow a firm hold and better alignment. There are some brackets which mount on the sides of which have a sort of clip to hold the bumper.
Headlamps - With hood open, per each headlamp there are two tabs on top of the headlamp which flip up to reveal two screws and a third screw on the front of the headlamp. With the screws loosened the headlamp has some play to put in a natural looking alignment to grill, bumper and fenders.
Fenders - have 3 screws on top. When loosened the fender moves slightly to provide clean looking alignment to other parts.
