Recovery Points?
Millerman
Are there any factory recovery point on the front or rear. I'm really not to worried about the rear as I normally just use a hitch mounted shackle but was wondering about the front. I've looked high and low at pics and forums and cannot find the info. I now have to wait till Wednesday to pick up my new to me LR3 so I can't look myself.
Cheers
Dan
duckdive
Remove plastic panel under front bumper for front recovery point. One turn on a few plastic screws
is all it takes. You can also do a search on this forum, I believe this has been covered
pretty well.
Millerman
pretty well.
Cheers thanks. I tried a search but I guess I didn't use the right phrase.
Do guys usually just take the panel off before they go wheeling. That makes sense I suppose. Being under the bumper is there a chance of damage from the strap?
duckdive
Yes to taking it off before getting on the trail.
No to the strap damage unless you do something careless.
jpljpl
...I normally just use a hitch mounted shackle...
You're LR3 has a hitch? :) Maybe yours has an aftermarket hitch installed, but the factory option is probably a little different than what you are expecting.
There is a rear recovery point as well, accessed via another removable panel.
You'll see once you pick up your new rig.
roverman
If you have the gazillion dollar receiver, a hitch shackle works fine. But in this case the factory tow point works great.
Millerman
Ok you now have me concerned. One of the first things I was going to do was get the dealer to install a hitch. Am I in for a surprise? I tow a lot of things and a hitch is a must.
beantmt
Find a used one on ebay/craigslist/local classified or buy new from http://www.bputah.com/. Also get the trailer wiring kit from http://www.roverparts.com/ and install it yourself. This will safe you a lot of money.
Wiring kit is $120 and hitch is $375 new. Pretty silly (and that's not even the genuine wiring kit).
roverman
I thought I spent $100 at bputah for the wiring, bought the hitch for $250 used. And you're not in for any surprise, I think jpl just meant you cant stick a recovery hitch into the stock 'hole' in the LR3, you need the receiver.
MArsel
