Need some help please!
EGCarp
Texas
Hello everyone! I need help with 2 codes.
LR3 started running rough, no power, check engine light on.
I changed the air filter, cleaned the throttle body and cleaned the 3 month old MAF.
I’m getting to codes P0113 Intake Air Temperature Sensor and code P0102 Mass or volume air flow sensor A circuit low.
I can’t locate the intake air temp sensor. Is it part of the MAF? If not, please tell me where to look for using kindergarten words. I’m new at this.
Any idea where these sensors are located would be of great help.
Thanks to all that answer!
remember5
Here is the relevant section of the manual in case you don't have it already. I assume you have a 4.4, if not I attached the 4.0 section as well.
  • Description and Operation.pdf
Sid1577
