2015 LR4 P0014 + P0024 Codes
Salanizi
Kuwait
Hello
With my never ending issues with my 2015, i got a check engine light yesterday and the car was jerking roughly.
This only happens when i am running at very low RPM's (usually when parking or traffic) whether going backwards or forwards.
Took the car to an indy, pulled multiple misfire codes (strangely all on bank 2) however we believe the culprits are P0014 + P0024 which i believe is the VVTI for the exhaust camshafts.
Question:
Could it be that the timing is actually off (i just had the car re-timed with valvetrain work two weeks ago, this problem was there before the timing job and persisted) ?
Could it be the camshaft sprockets themselves? Or simply the VVTI sensors (i hope so)?
I could easily order the sensors and replace them, but i need proper diagnosis.
All O2 sensors have been replaced with OEM Bosch units
I appreciate any help with this.
strally
Los Angeles, USA
Hello
Question:
Have you fix the issues? I have the same problem but even worst! 2016 LR4 3.0 SC with P0011, P0021, P0014, P0024. I replaced all camshaft sprockets but still show same codes!!
MrRodgers
