2000 land rover discovery 2
brucebatman73
just bought it and came with no owners manual, ... is it all time 4 wheel or do I have to put it in 4 wheel.. has a low, neutral, and high shifter with some type of directions on dash in front of shifter but cant quite ffllow what its trying to say. any help would be appreciated..
As stated in your duplicate post... it is full time 4 wheel drive, the Hi/Low is more for off roading.
brucebatman73
hey thanx buddy, thats what i thought but the dudes at the dealership where i bought it said that it wasn't. I told them that I thought it was..... sorry about the duplicate posts.. new to forums as u might coul tell...
No issues... Since you just bought this used, if I could make a few recommendations. First and for most read though as many of these posts as you can (you will learn a lot about your vehicle).
Second, no matter what the dealer told you, if you don't know the real history behind your new vehicle I would recommend starting to do some preventive maintenance.
Plugs, wires, a can of seafoam in the gas tank, Have the battery and the Alternator checked, Check the S-Belt, Change all the fluids, included the Front and rear Diffs, the transfer case and the transmission.
Then I would also check the U-Joints on the driveshafts, they are non-greaseable and when they go bad it could cost you a transmission.
This all does not have to be done overnight, but at minimum I would get to the U-Joints and the Belt, then work from there.
tragic1
