How to program the handset
Don't know about cutting the key, though...
NOTE: New handsets are supplied in pairs.
If a new handset is required, it will require
initialisation to the ECU using the
following procedure:
1. Starting conditions: ignition off, doors unlocked,
bonnet switch depressed.
2. Carry out instructions 3. to 9. within 8 seconds.
3. Switch ignition ON.
4. Switch ignition OFF.
5. Lock doors.
6. Unlock doors.
7. Release bonnet switch.
8. Switch ignition ON.
9. Switch ignition OFF.
If alarm is correctly accessed, horn will sound and
LED will light. It is now possible to programme two
handsets of correct frequency to vehicle alarm ECU.
This must be carried out within two minutes.
10. Press and hold down button on first handset until
dash LED flashes.
11. Repeat instruction 10. for second handset.
12. The LED will extinguish if both handsets have
been initialised correctly.
